Surface density
Posted: Wed Nov 06, 2024 8:47 am
Hello! I would like to determine the dot density of my scans. My approach is to use the “surface density” function via “compute geometric features”. This gives me the points per m3 , right? If I have an average of 750 thousand points per m3 in the scan in the example, then I would have 0.75 points in one cm3. That doesn't make much sense in my case, as I have soil surfaces. Could I then also take it as an area and say there are 75 points per cm2? Or is there an easier or different way? Thanks for the help in advance! - Antonia
