Multiple scalar to coordinate
Posted: Sat Feb 03, 2024 5:32 pm
by mariolino
hello Daniel
I would like to ask you because I would really need it, the possibility of setting the coordinates from the scalars, not like now that you have to do one coordinate at a time, but like you did recently for the normals, where a box is proposed and in a few steps you can assign all coordinates. I use it a lot because I do calculations between the scalars and calculate new coordinates which I then need to assign!
thanks
Mariolino
Re: Multiple scalar to coordinate
Posted: Mon Feb 05, 2024 10:39 pm
That's now done!
You can test that in the latest 2.13.beta version.
Mind however that it will only work if you select one entity at a time.
Posted: Thu Feb 08, 2024 10:03 am
by mariolino
Thank you Daniel, many thanks, it works very well !!!
