Multiple scalar to coordinate
mariolino
Post by mariolino »
hello Daniel
I would like to ask you because I would really need it, the possibility of setting the coordinates from the scalars, not like now that you have to do one coordinate at a time, but like you did recently for the normals, where a box is proposed and in a few steps you can assign all coordinates. I use it a lot because I do calculations between the scalars and calculate new coordinates which I then need to assign!
thanks
Mariolino
Re: Multiple scalar to coordinate
That's now done!
You can test that in the latest 2.13.beta version.
Mind however that it will only work if you select one entity at a time.
mariolino
Post by mariolino »
Thank you Daniel, many thanks, it works very well !!!
mariolino
Post by mariolino »
hello Daniel,
is it possible to extend the functionality of ‘set SFs as coords’ with the possibility of directly imputing in X,Y,Z a real number (in addition to the possibility of choosing a scalar) to be assigned directly to all coordinates, it is very useful for speeding up certain tasks such as flattening a cloud on a plane with z assigned, for example.
Thank you
Mario
Ah, that would be more logically be done in two steps (first create a 'constant' SF, and the map it to the coordinate).
But to flatten out a cloud, it's maybe faster to use 'Edit > Multiply / Scale' and set 0 for the dimension to flatten. And then you can 'translate' the cloud if you want to shift it to a particular Z value for instance.
mariolino
Post by mariolino »
Another system is with the 4x4 matrix to put the 3.3 member at 1e-20. Then apply a translation with the 3,4 member .
I am already using all these methods......
The fastest thing would be to do it directly from ‘set SFs as coords’ ......
Thank you very much from now on if you get a chance to implement it ....
Mario
