Height Grid Generation
Posted: Mon Oct 01, 2012 3:15 pm
by gonzalotap
Why when you build a height grid the empty cells fill with a fixed value. the colour is purple.
There is a option to choose thisvalue but don´t work.
and it´s posible to choose the scalar field to fill the cells to the grid.
Best regards
Re: Height Grid Generation
Posted: Wed Oct 03, 2012 7:36 am
Indeed the dialog is misleading here as it suggests that the "replacement value" option is available for images (while only the 'purple' transparent pixels are working right now). I'll try to fix this (either the dialog or I'll make the replacement value work also for images if you think it's a good idea?).
I'll look at these points for the next version.
Posted: Thu Nov 15, 2012 2:42 pm
by gonzalotap
Hi Daniel, in the new version still can not replace the value of empty cells?
or I'm doing wrong.
Best regards
Posted: Thu Nov 22, 2012 8:18 pm
I'll check that before the next release!
Posted: Thu Nov 29, 2012 2:45 pm
Ok, the last github trunk version is fixed/updated!
It will be available in the next release (before Christmas ;).
