Height Grid Generation
gonzalotap
Post by gonzalotap »
Why when you build a height grid the empty cells fill with a fixed value. the colour is purple.
There is a option to choose thisvalue but don´t work.
and it´s posible to choose the scalar field to fill the cells to the grid.
Best regards
Re: Height Grid Generation
Indeed the dialog is misleading here as it suggests that the "replacement value" option is available for images (while only the 'purple' transparent pixels are working right now). I'll try to fix this (either the dialog or I'll make the replacement value work also for images if you think it's a good idea?).
I'll look at these points for the next version.
gonzalotap
Hi Daniel, in the new version still can not replace the value of empty cells?
or I'm doing wrong.
Best regards
I'll check that before the next release!
Ok, the last github trunk version is fixed/updated!
It will be available in the next release (before Christmas ;).
