apply global shift
Posted: Fri Sep 26, 2014 1:19 pm
by piero539
is there a way to definitely apply temporary global coordinates shift to a cloud to save cleaned coordinates?
I open a cloud whith a good global shift... but when I save global coordinates are re-added :( ... this is great when I want real placing, but I need to real move point near origin...
I also try 2.5.6 beta but I don't find a way to to that.
thanks,
CloudCompare is really a great software... with this features solve me a lot of trouble...
Piero
Re: apply global shift
Posted: Fri Sep 26, 2014 1:41 pm
Yeah, simply edit the Global Shift/Scale information (Edit > Edit global shift and scale) then reset all the values (i.e. 0 for all translation values and let 1 for the scale).
Posted: Fri Sep 26, 2014 4:15 pm
by piero539
yeahhh... It works... so simple!!
thanks a lot
Piero
Posted: Mon Nov 28, 2016 4:19 pm
by Philipppuschmann
Hi everyone,
thanks for the description. I can use now cloudcompare and I even figured out the shifting. I have only one problem:
The shifting is not permanent.
I looked everything up but after closing the session the coordinate system is resetted. I cant find any "save" button or something simelar. The only thing I found was in
Edit –> Edit global shift and scale
There I can theoretically reset the transformation to a new one but i couldnt save that either.
Tanks for help.
Philipp
Posted: Mon Nov 28, 2016 7:31 pm
Have you saved the entity? You must highlight it and then use 'File > Save'.
