[Done] Load PTS in command line mode
Posted: Thu May 22, 2014 7:45 am
by roggero
When I try to load a PTS in command line mode, it is Always necessary to set "skip line 1" manually. In this way Scripting is not efficient because require this input by the operator. Can be add this parameter as option in the command -O?
Thanks,
Marco
Re: Load PTS in command line mode
Posted: Fri Jul 04, 2014 11:21 am
That's done: '-O -SKIP {number of lines}' (see http://www.cloudcompare.org/doc/wiki/in ... ommandLine).
Will be available in the next release (soon).
