[Done] Terrestrial scans alignment
Posted: Wed May 21, 2014 8:48 am
by roggero
It can be useful to lock the rotations around X and Y in the cloud alignment. For terrestrial laser scans only the rotation around Z must be estimated. The scan origin can also be known by GPS or by topographic survey, and optionally can be set manually and locked.
Thanks,
Marco
Re: Terrestrial scans alignment
Posted: Wed May 21, 2014 9:22 am
I'll add this to the TODO list.
Posted: Thu May 22, 2014 7:38 am
by roggero
Thanks Daniel!
Posted: Thu Jul 03, 2014 9:48 am
The rotation axis can now be locked in both 'point-pair based' and ICP registration tools.
For the origin, you can already set points manually in the 'point-pair based' alignment tool. You could also achieve an equivalent operation with the 'Global Shift & Scale' mechanism (see the 'Edit > Edit Global Shift and Scale' method of the v2.5.5 - should be released soon).
