[Done] ascii opening in Command line
Posted: Fri Mar 28, 2014 4:20 pm
by Dimitri
I had never tried the command line features, and these are just great...
2 command line request:
.would it be possible to have a fully silent mode for the command-line opening of ascii files ? Because right now you still get the pop-up, and for well-behaved ascii files it requires a click (which somehow defeat the purpose of automatic scripting ;-).
.it would be great to have a way to activate a specific scalar before to call for an operation on it (e.g. -SF_active {number})
Thanks a lot
Dimitri
Re: ascii opening in Command line
Posted: Mon Mar 31, 2014 7:02 am
For the first one, I'll look at this (is it really a "normal" ascii file?).
And for the second one, I'll add this to the TODO list (mustn't be too hard to do though ;)
Posted: Mon Mar 31, 2014 7:30 am
by Dimitri
these are "normal" ascii files: no header, no special characters, just plain XYZ + scalars. When we load them through the command line, we just have to click "ok" nothing else.
Cheers
Dim
Posted: Thu Apr 10, 2014 9:28 am
Ok, I've set the ASCII file loading procedure silent... if the cloud has less than 5 columns. After that, we don't know (for sure) if the 3 additional columns are colors, normals or even 3 scalar fields... In this case we could let the user specify precisely the file content, but it will be much more complicated to implement (I've added this to the TODO list already).
And for the other point, I've added a new option '-SET_ACTIVE_SF {index}' to let the user choose the activate scalar field (on all loaded clouds).
Posted: Thu Jun 19, 2014 8:12 am
by MJS
Daniel, It would be useful if on either the command line or GUI load of an ASCII file it looked at the header and took the column information from that as default. In always add //X Y Z R G B to the top of any "coloured" ASCII file. Mike.
Posted: Fri Jul 04, 2014 10:44 am
Ok that's done. The ASCII importer is a little bit smarter now. It will try to guess the columns attribution from the header if any.
The header must have the same number of elements as the number of columns in the file. It must also use the same separator character. The header line should start by '//' so that CC can detect it automatically. Eventually the column names must be standard (i.e. 'X', 'Y', 'Z', 'R' or 'Red', 'Nx' or 'NormX', etc.).
In command line mode, if CC has detected everything it will open the file automatically. Otherwise, through the standard CC interface, the dialog will still appear because we are never sure of anything, and also we don't know what the user wants to do (e.g. swapping X and Z columns, etc.)
This will be available in the next official release (soon!).
