Can I export STL files after alignment in CloudCompare?
Posted: Wed Jun 17, 2026 3:25 pm
Hi everyone,
I aligned two STL meshes using the **"Align (point pairs picking)" / partially aligned objects** workflow in CloudCompare. After the alignment, I would like to evaluate the RMS error only in specific regions of the meshes.
My first thought was to crop the meshes after they were aligned, but I couldn't find a way to export the STL files while preserving the transformation applied during the alignment process.
Is there a way to:
1. Export STL meshes after alignment, keeping their aligned position?
2. Crop both meshes in their aligned position and calculate the RMS only for the selected region?
3. Evaluate RMS for specific regions of a mesh-to-mesh comparison without cropping the entire model?
I tried cropping only the reference (master) mesh, but as far as I understand, CloudCompare still calculates the RMS considering the entire mesh, including areas that are missing on the test mesh, which may be affecting the results.
I'm working only with meshes (STL files), not point clouds.
Any suggestions would be greatly appreciated. Thanks!
Is there a way to:
