Translate/Rotate (Advanced) – exact 90° backward rotation causes a position “jump” (unexpected translation), while 90° f
Posted: Wed Feb 04, 2026 5:14 am
Title: Translate/Rotate (Advanced) – exact 90° backward rotation causes a position “jump” (unexpected translation), while 90° forward is fine; 89/91 or 90.0001° works
Hi CloudCompare devs,
I’d like to report a reproducible issue I’m seeing in the Interactive Transformation tool.
Context
- Tool: Edit > Translate/Rotate (Interactive transformation), using the Advanced panel
- Symptom: the rotation itself looks correct, but the entity position suddenly “jumps” (as if an unexpected translation is applied).
Key behavior
- Rotating by exactly 90° in the “forward” direction works normally (no jump).
- Rotating by exactly 90° in the “backward” direction causes the position jump.
- 89° and 91° do not show the issue (backward is fine).
- Workaround: 90.0001° (instead of 90.0000°) works fine, including in the backward direction.
- Another workaround: applying +90° in multiple steps (validate/apply each step) can be stable, while a single -90° step may jump.
Steps to reproduce
1) Select a mesh/entity.
2) Open Edit > Translate/Rotate.
3) In Advanced, set Rotate Around = Origin (or the default/automatic setting), and set the rotation axis to Y.
4) Set the angle to exactly 90.000000 degrees.
5) Click “Forward” rotation: works normally.
6) Click “Backward” rotation: the entity position jumps.
Questions
- Is this a known issue with Interactive Transformation at exact 90° (backward only)?
- Is the recommended workflow to avoid exact 90° in this tool (e.g., use 90.0001°), or to use Apply Transformation (Ctrl+T) / a custom coordinate system pivot instead?
Thank you!
Note: I’m a non-native English speaker, and this post was written with assistance/advice from ChatGPT (GPT-5.2).
Context
Key behavior
Steps to reproduce
Questions
Thank you!
