Cloud Compare with Python automation
benb
Post by benb »
I'd like to build a little interface that will load a bunch of LAS files into CC, process them and save out files. Pretty straightforward.
I'd like to control it with Python and use multiple instances of CC running concurrently, with Python feeding files to the instances as they complete their processing of the individual LAS files... If i can get it to work for a single instance of CC, then I'd like to expand it to multiprocessing.
it may be helpful for best assessment to review the specific workflow I hope to achieve, and to determine if these can be accomplished perhaps through the plugin, CLI, or the CloudComPy interface (which I have found VERY difficult to build for use). CloudComPy requires Qt5 which now does not provide some required dependencies, and I have run into days of wasted time trying to build the CloudComPy tool. It seems broken to me. Or maybe it broke me! I have temproarily quit trying to build CloudComPy with CMake and Visual Studio, it was hellish.... anyway my goal is pretty simple and I could do this all by hand but automation by software control seems sensible - so seeking a howto that actually works is my state now.
First, Open the next file.
Then in the Open LAS file window/ Loading/Standard Fields/ Select All/ Apply.
Then in the Global Shift/Scale window, click Yes.
Then in the DB Tree window, select the lowest child element in the DB Tree.
Then in the Properties window, under Scalar Fields (note: NOT under CC Object/ Scalar field !!), set Scalar Fields/ Active to Classification.
Then activate the Min/Max tool (also known as the Filter points by value tool) and set its Range to be 1.1 to 2.1 and select Export.
Then ensure that the newly filtered point cloud (lowest child object in the DBtree is selected.
Then export/save the filtered point cloud with a proper name to a proper lcation.
Then with the filtered point cloud still selected in the DB Tree, activate the Tools/ Projection/ Rasterize (and contour plot) tool (also known as the Convert a cloud to 2D raster tool).
Then, in the Rasterize tool set step to desired setting (let's say 1.0 to get started to save time during testing, we can make an .ini file to make that setting be user-accessible, we will want to set it during production to .5, .3, or other setting), active layer= Cell height values, Projection direction= Z, cell height= median, Std. dev. layer= Intensity, project SF's= ON and median value selected, resample point cloud= ON, Empty cells/ Fill with= let's start with Interpolation for getting started, (we will use kriging during production, this can be user- selectable, like step height, in the .ini file).
Then it should Activate the Update Grid function, which will open the Grid Size window. Select Yes to that window.
Then observe for completion of the updating of the grid.
Then when the grid is updated, in the Export tab of the Rasterize tab, select Raster, name the file properly and set its Save location properly and save it.
Therefore the processing of each file would produce two derivative files; the first would be an LAS file of the filtered point cloud, the second would be a TIF raster of the rasterized filtered point cloud.
Is there anyone who could help me with this in any way? Suggestions, collaboration, recommendations for solutions??
Should I try building CloudComPy with Docker or Conda instead of CMmake/VisualStudio?
I spent time building a batch file but learned it cannot control the tools inside CC, so I need something that can do that. The Plugin maybe?
I thought external control would be most flexible and extensible, but CloudComPy is a grizzly bear to build, so I am open to new ideas.
Thank you,
-benb
Re: Cloud Compare with Python automation
So first, CloudCompy is a different project. Any question related to CloudCompy should be asked on its github page. If can be about your compilation issues, or about whether this is feasible or not.
But on my side, I can say that most of these operations can already be performed with the CLI mode. If not all... And if something is missing, it may not be too complicated to simply create or improve the CLI option that's missing or incomplete.
benb
Post by benb »
I will review your Wiki docs for more information about the CLI.
Would it make sense to manage the CLI with Python scripting?
Simple is good, my task objectives are few and not complex.
I have a collection of LAS files to filter, rasterize, and save.
My goal is to automate to get it done consistently and fast.
There are only about 600 files, each is about 1gb in size.
They take about an hour to "Upgrade grid" to rasterize,
I wonder if there is a way to "listen" to their progress
when "Upgrade grid" process is complete, file save.
It could be done crudely with a timer, but that is
not a secure way to ensure great consistency.
Such are the considerations i am pondering.
CloudComPy requires many dependencies.
I'd like to keep things as simple as I can.
The CLI sounds like a possible solution
if the issue of saving grid is soluble.
An elegant solution might require
some sort of low level trigger
to facilitate the Save event.
I will see the Wiki entries.
Maybe I will post again.
I will check again also
to see any new reply.
Keeping it simple,
getting it done.
fast and right,
Thank you:
-benb
See the -OUTPUT_RASTER_XXX options to export the grid as a geotiff image (see https://www.cloudcompare.org/doc/wiki/i ... _line_mode).
And sadly, no, you won't get any progress report via the CLI (apart from the small GUI and progress bar if you don't activate the SILENT mode, but sadly in this case I believe you would have to 'confirm' the process by clicking on OK each time, which kills the idea of automation...).
