2DLabel - Edit Body
SimonLB
2DLabel - Edit Body
Post by SimonLB »
Hi there,
For visualisation purposes I need to have some text displayed in my scene. It’s a basically a 3D mesh with a high-resolution texture and some polylines (boundaries and stuff). I already figured out that there are 2DLables which can be imported via an xyz ascii file to display some text.
Now I want to improve the way how the labels are displayed and add a line break instead of spaces. Every line break command I tried within the text didn´t work so far.
My goal is to achieve something like the picture above. Can you edit the body of the label, so it doesn't display the coordinates (etc.) of the vertices but some text I want? Or is there a way to add line-breaks into the legend? Both would work for me.
Thank you very much for any ideas or hints.
Regards Simon
Re: 2DLabel - Edit Body
Sadly, you won't be able to achieve that apart from changing the code of CloudCompare...
