Shifting while point picking to draw a line.
Posted: Thu Mar 20, 2025 9:43 am
by Hema
I have a point cloud data which I have loaded in the cloud compare tool. I am picking the points continously to draw a line(my application is to draw the white lines on the huge GIS data), If I ZOOM IN, the precision of the picked point is good, Since it is a larger data I cannot always zoom in and pick.
So if I ZOOM OUT and pick a point, some other points will be picked(there is a random shift) and its not consistent, is there any work around for this or suggest any rectification for the same, If you guys need any clarification further I can give more info on the issue.
Re: Shifting while point picking to draw a line.
Posted: Sat Mar 22, 2025 8:32 am
Are you using the 'Trace polyline' tool?
If yes, then you can keep a high level of zoom, pan the view with the right mouse button, then click on the '+' icon to continue the current polyline edition.
Posted: Mon Mar 24, 2025 5:23 am
by Hema
I appreciate the timely response and thanks for developing this awesome open source tool. Although your solution will solve that problem....
But I have the task of doing annotation for the data size of around 2000 km, and zooming in and out will be tiresome and exhausting, all i am trying to do is do the annptation or draw the polyline in zoomed out stage. I also don't mind adding a new button or new functionality, please do suugest, will be waiting for the reply..............
Posted: Mon Mar 24, 2025 10:57 am
Well, since you are zoomed out, there's probably dozens if not hundreds points in one pixel. There's no way CC can choose 'the right one' magically...
Posted: Mon Mar 24, 2025 11:44 am
by Hema
Thankyou for the information
