Converting a point cloud of a substation to a mesh
Posted: Tue Mar 04, 2025 5:24 pm
Full disclosure, my experience with CloudCompare (or any other point cloud software) is very limited.
I am attempting to convert the point cloud I have of a segment of a substation into a mesh to use in ArcGIS Pro using the Poisson Recon plugin. The resulting mesh is very poor quality - likely due to the complex nature of the object and the software's way of triangulating this (photo attached). My Octree depth is set to 10, and output density as SF is checked. When computing the normals, I have set a higher radius of 0.765 and a +Z orientation.
Wondering if there is anyone else here who has experience dealing with these types of meshes, and if there is any settings I can change (or perhaps a different workflow to follow) to make the end result better?
Thanks in advance!
Thanks in advance!
