corrupt .bin
Posted: Wed Nov 27, 2024 10:01 pm
by PablerasBCN
Hi.
I've gotten a .bin corrupted.
I copied the file and copies ok, but same err, any way to try to have it checked or extract some work out of it?
[22:42:58] [BIN] Opening file 'E:\LIDAR_JAPAN\MMS_5_Prototype_5\MMS\temp.bin'...
[22:42:58] [BIN] Version 3.4 (coords: float / scalar: float)
[22:43:21] File seems to be corrupted
[22:43:21] Failed to read file (file position: 5844418700 / 5844418700
[22:43:21] An error occurred while loading 'temp': see console
[22:45:36] [BIN] Opening file 'E:/LIDAR_JAPAN/MMS_5_Prototype_5/MMS/temp.bin'...
[22:45:36] [BIN] Version 3.4 (coords: float / scalar: float)
[22:45:49] File seems to be corrupted
[22:45:49] Failed to read file (file position: 5844418700 / 5844418700
[22:45:49] An error occurred while loading 'temp': see console
[22:58:25] [BIN] Opening file 'E:/LIDAR_JAPAN/MMS_5_Prototype_5/MMS/temp - copia.bin'...
[22:58:25] [BIN] Version 3.4 (coords: float / scalar: float)
[22:58:45] File seems to be corrupted
[22:58:45] Failed to read file (file position: 5844418700 / 5844418700
[22:58:45] An error occurred while loading 'temp - copia': see console
Re: corrupt .bin
Posted: Fri Nov 29, 2024 6:18 pm
Indeed, it seems the file is truncated (the error happens at the very end of the file).
I guess if you are able to share the file with me (admin@cloudcompare.org - but it's huge!) I could try to extract something out of the file.
Re: corrupt .bin
Posted: Sat Nov 30, 2024 10:06 pm
Ok, for the records, the latest 2.14.alpha version will now give the user the choice to proceed and load the (potentially partial) clouds that CC was able to load until an issue occurred.
The caveat being that CC might crash afterwards ;)
Re: corrupt .bin
Posted: Sat Nov 30, 2024 10:40 pm
by PablerasBCN
I confirm it works, TX so much Daniel.
