Page 1 of 2
Render image max size
Posted: Sat Dec 21, 2013 11:49 am
by jfhullo
Hi there,
can you tell us what is the maximum size (resolution) for an image using Render to file, cause CC chrashes when image seems too large.
JF
Re: Render image max size
Posted: Sat Dec 21, 2013 5:31 pm
In fact the max size depends mainly on the available memory on your graphic card. But if you "overflow" it shouldn't make CC crash (so we could speak of a bug here ;)
What's the size at which the crash occurs?
Posted: Wed Jan 15, 2014 1:27 pm
by jfhullo
Using an iMac, it crashes around 7000+ pixels. I tried to make a large render of an orthographical view using new scale parameter ;)
This is really useful to produce a "map" in th TopView, but I can 't get really nice resolution, except if I make many exports and then stitch them in a third party soft.
Thanks for answering Daniel.
JF
Posted: Wed Jan 15, 2014 2:43 pm
<troll mode on>On iMac?! Does those things even have decent GPUs ;)</troll mode off>
You should test it on another configuration. With my GeForce GT 640M (on a DELL laptop) I can go up to 15200 x 7300 pixels (~128 Mo pixels / corresponds to 9x zoom). Above 9x zoom I get an error message (so what bugs me a little is that CC crash on your side...).
What's your graphic card by the way?
Posted: Mon Jan 20, 2014 9:16 am
by jfhullo
Ouch, I have to admit that this object, an iMac, is absolutely not a decent computer. It just has a chipset (Intel Iris 5200) that shares up to 1Go of RAM.
BUT, please note that this computer is only my home-internet-movie platform... :)
If this issue, as it seems, is only related to the graphic card specs, this is not a problem anymore, i'll use a better one!
I don't know if there is a way to estimate the max resolution before starting the export, to prevent from fail or crash.
JF
Posted: Mon Oct 26, 2015 12:37 pm
by Aitor
I do not get to obtain a high resolution image with Render to file command . I read that it may be for the grafic card.I think it's not my problem; my graphics card is Nvidia GforceGTX980 .
When I try to keep at a high resolution (Zoom X5 ), the image is saved with a lower resolution. CloudCompare displays the following error message:
[cc GLWindow::renderToFile]OpenGL error:invalid operation
and while stored on the console to a high-resolution, photo has not high-resolution
¿¿¿What is the problem???I'm going crazy ;)
Posted: Mon Oct 26, 2015 1:10 pm
Even high-end graphic cards have a limit of 64 Mb per texture (therefore depending on the screen size you might hit this limit with a zoom of X5).
Is it working with a zoom of X4?
Otherwise can you post the following information:
- the graphic card model and manufacturer that is displayed in the Console when you start CloudCompare
- the OpenGL version
Posted: Tue Oct 27, 2015 9:21 am
by Aitor
I've tried all the zoom. The only thing that gives good results is the zoom X1 but the resolution is low and I need higher resolutions.
GL version: 4.5.0 NVIDIA 355.82
Graphic card manufacture: NVIDIA Corporation
Aitor
Posted: Tue Oct 27, 2015 10:52 am
This is weird indeed. What version of CC are you using? The 2.6.2? And on which OS?
Posted: Tue Oct 27, 2015 12:09 pm
by Aitor
The version of CC is 2.6.1 and the OS is Windows10
For example, when I save an image with Zoom X3 ( 2658x1695 ), the image size is saved with only 172 kb
