Collapse Label
dcobra
Collapse Label
Post by dcobra »
I used to be able to right click on a label to collapse it and only see the title. This doesn't appear to be working anymore. Is there another shortcut key?
Best,
Cody
Re: Collapse Label
It should still work (at least in the 2.13.2 version). Which version / setup are you using?
dcobra
Re: Collapse Label
Post by dcobra »
I'm using 12.13.2 on windows 10. I tried it on another computer running the same version and it works. Not sure why it works on one machine and not the other.
Re: Collapse Label
Maybe a screen resolution or a graphic driver issue, hard to guess...
