About 2.5D Volume Surface
Posted: Fri Jun 14, 2024 5:00 am
by SAYURI
hello,
I would like to ask about how to find the area using 2.5D Volume.
Is the Surface in Results the area of ​​a 2.5D grid (plane)?
I calculated the area of ​​the rock with 2.5D Volume.
It seems like a calculation result that ignores the unevenness of the rock and flattens the surface.
Is the height range of the unevenness not calculated?
Sorry if this has already been posted.
Re: About 2.5D Volume Surface
Posted: Sat Jun 15, 2024 10:25 pm
by DA523
z=0.zip
(744.08 KiB) Downloaded 1289 times
yes, it is a projected area, not 3d shaped area
check attached example
Posted: Sat Jun 15, 2024 10:32 pm
by DA523
To find real 3d shaped area ,you can mesh it and then use measure surface
edit -->mesh-->measure surface
Posted: Mon Jun 17, 2024 1:24 am
by SAYURI
DA523 Hello
Thank you for the easy-to-understand examples.
Thank you for also showing me how to solve the area.
