"Windows fatal exception: code 0xc000001d" when trying to install PCL plugin
Posted: Wed May 29, 2024 1:53 pm
Good day,
I have installed and used CloudComPy without any issues, but when it came to cloud registration I encountered a problem when trying to run following code:
I get the following message in Spyder's console:
("Kernel wird neu gestartet" means "restarting the kernel")
I am using Python3.10, and the CloudComPy310_20240420 version, with miniconda3 on Windows 10 Enterprise LTSC operating system.
When trying to import other plugins the same way, like PCV plugin, I didn't get any error and it runs just fine.
Thanks in advance!
import cloudComPy as cc
if cc.isPluginPCL():
import cloudComPy.PCLCode: Select all
QFileSystemWatcher: Removable drive notification will not work if there is no QCoreApplication instance.
JsonRPCPlugin::JsonRPCPlugin
Main thread:
Current thread 0x000032f4 (most recent call first):
File "<frozen importlib._bootstrap>", line 241 in _call_with_frames_removed
File "<frozen importlib._bootstrap_external>", line 1176 in create_module
File "<frozen importlib._bootstrap>", line 571 in module_from_spec
File "<frozen importlib._bootstrap>", line 674 in _load_unlocked
File "<frozen importlib._bootstrap>", line 1006 in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 1027 in _find_and_load
File "C:\Users\yanovetsa\CloudComPy310_20240420\CloudComPy310\CloudCompare\cloudComPy\PCL\__init__.py", line 44 in <module>
File "<frozen importlib._bootstrap_external>", line 883 in exec_module
File "<frozen importlib._bootstrap>", line 688 in _load_unlocked
File "c:\users\yanovetsa\ccpy\find_ridges.py", line 54 in <module>
File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\py3compat.py", line 356 in compat_exec
File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 473 in exec_code
File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 740 in _exec_cell
File "C:\Users\yanovetsa\AppData\Local\miniconda3\envs\CloudComPy310\lib\site-packages\spyder_kernels\customize\spydercustomize.py", line 689 in runcell
File "C:\Users\yanovetsa\AppData\Local\Temp\ipykernel_10968\1630711856.py", line 1 in <module>
Main thread:
Kernel wird neu gestartet...I am using Python3.10, and the CloudComPy310_20240420 version, with miniconda3 on Windows 10 Enterprise LTSC operating system.
Thanks in advance!
