I am trying to load a taining file in 3D masc, but I get an error saying that it failed to lad the training file
What could be the error ?
Thank you
here is my training file in a .txt format:
# NAMES
cloud: PC1= # let the filename blanck if not needed, but keep the = sign
# CORE POINTS
core_points: PCX
# SCALES
scales: 0.1;0.2;0.75;1;2;5 # scales as a list
# FEATURES
feature: Z_SCx_MEAN
feature: Z_SCx_MODE
feature: Z_SCx_MEDIAN
feature: Z_SCx_STD_PC1
feature: Z_SCx_STD
feature: ROUGH_SCx_PC1
feature: ANISO_SCx_PC1
feature: SPHER_SCx_PC1
feature: LINEA_SCx_PC1
feature: PLANA_SCx_PC1
feature: CURV_SCx_PC1
feature: Zmin_SCx_PC1
feature: R_SC0_PC1
feature: G_SC0_PC1
feature: B_SC0_PC1
Failed to load the training file (SOLVED)
Re: Failed to load the training file
Did you read the messages in the CloudCompare console? It helps to solve syntax issues.
Did you read the documentation on the syntax of features?
=> https://lidar.univ-rennes.fr/sites/lida ... syntax.pdf
=> https://lidar.univ-rennes.fr/node/11
1) You have a 'core_points: PCX' but PCX is not defined elsewhere, replace PCX by PC1 if this is what you want.
2) The following set of parameters works (syntax corrected):
# NAMES
# CORE POINTS
core_points: PC1
# SCALES
# FEATURES
feature: Z_SCx_MEAN_PC1
feature: Z_SCx_MODE_PC1
feature: Z_SCx_MEDIAN_PC1
feature: X_SC0_PC1
feature: G_SC0_PC1
feature: B_SC0_PC1
# NAMES
# CORE POINTS
core_points: PC1
# SCALES
# FEATURES
feature: X_SC0_PC1
feature: G_SC0_PC1
feature: B_SC0_PC1
