build problem on Ubuntu 22.04.3 LTS
Posted: Mon Jan 15, 2024 3:50 pm
Thanks for the great software.
I am trying to build on Ubuntu 22.04.3 LTS (WSL on windows 11).
Firstly I could not find qt5-default. I tried several suggestions on Google but none fixed the cmake build errors found below.
Then I did the cmake steps as mentioned in the BUILD.md file
Several components build fine, but then I get:
Any ideas?
The output from my qtdiag is
I did add the QT_SELECT=5 environment variable myself to try and make up for the missing qt5_default.
Any help much appreciated.
regards
Paul
Building CXX object qCC/CMakeFiles/CloudCompare.dir/CloudCompare_autogen/mocs_compilation.cpp.o
In file included from /home/paulus/projects/cloudcompare/CloudCompare/build/qCC/CloudCompare_autogen/EWIEGA46WW/../../../../qCC/ccGraphicalTransformationTool.h:24,
from /home/paulus/projects/cloudcompare/CloudCompare/build/qCC/CloudCompare_autogen/EWIEGA46WW/moc_ccGraphicalTransformationTool.cpp:9,
from /home/paulus/projects/cloudcompare/CloudCompare/build/qCC/CloudCompare_autogen/mocs_compilation.cpp:27:
/home/paulus/projects/cloudcompare/CloudCompare/build/qCC/ui_graphicalTransformationDlg.h: In member function ‘void Ui_GraphicalTransformationDlg::setupUi(QDialog*)’:
/home/paulus/projects/cloudcompare/CloudCompare/build/qCC/ui_graphicalTransformationDlg.h:322:29: error: ‘class QDoubleSpinBox’ has no member named ‘setStepType’; did you mean ‘setStyle’?
322 | incrementalRotSpin->setStepType(QAbstractSpinBox::AdaptiveDecimalStepType);
| setStyleThe output from my qtdiag is
paulus@roomys2:build$ qtdiag
Failed to create Vulkan instance: -9
Failed to create platform Vulkan instance
Vulkan instance is not valid
Qt 5.15.3 (x86_64-little_endian-lp64 shared (dynamic) release build; by GCC 11.3.0) on "xcb"
OS: Ubuntu 22.04.3 LTS [linux version 5.15.133.1-microsoft-standard-WSL2]
Architecture: x86_64; features: SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 AVX AVX2
Environment:
QT_SELECT="5"
Features: QT_NO_EXCEPTIONS
Library info:
PrefixPath: /usr
DocumentationPath: /usr/share/qt5/doc
HeadersPath: /usr/include/x86_64-linux-gnu/qt5
LibrariesPath: /usr/lib/x86_64-linux-gnu
LibraryExecutablesPath: /usr/lib/x86_64-linux-gnu/qt5/libexec
BinariesPath: /usr/lib/qt5/bin
PluginsPath: /usr/lib/x86_64-linux-gnu/qt5/plugins
ImportsPath: /usr/lib/x86_64-linux-gnu/qt5/imports
Qml2ImportsPath: /usr/lib/x86_64-linux-gnu/qt5/qml
ArchDataPath: /usr/lib/x86_64-linux-gnu/qt5
DataPath: /usr/share/qt5
TranslationsPath: /usr/share/qt5/translations
ExamplesPath: /usr/lib/x86_64-linux-gnu/qt5/examples
TestsPath: /usr/tests
SettingsPath: /etc/xdg
Standard paths [*...* denote writable entry]:
DesktopLocation: "Desktop" */home/paulus/Desktop*
DocumentsLocation: "Documents" */home/paulus/Documents*
FontsLocation: "Fonts" */home/paulus/.local/share/fonts* /home/paulus/.fonts /usr/local/share/fonts /usr/share/fonts /var/lib/snapd/desktop/fonts
ApplicationsLocation: "Applications" */home/paulus/.local/share/applications* /usr/local/share/applications /usr/share/applications /var/lib/snapd/desktop/applications
MusicLocation: "Music" */home/paulus/Music*
MoviesLocation: "Movies" */home/paulus/Videos*
PicturesLocation: "Pictures" */home/paulus/Pictures*
TempLocation: "Temporary Directory" */tmp*
HomeLocation: "Home" */home/paulus*
AppLocalDataLocation: "Application Data" */home/paulus/.local/share/QtProject/qtdiag* /usr/local/share/QtProject/qtdiag /usr/share/QtProject/qtdiag /var/lib/snapd/desktop/QtProject/qtdiag
CacheLocation: "Cache" */home/paulus/.cache/QtProject/qtdiag*
GenericDataLocation: "Shared Data" */home/paulus/.local/share* /usr/local/share /usr/share /var/lib/snapd/desktop
RuntimeLocation: "Runtime" */mnt/wslg/runtime-dir*
ConfigLocation: "Configuration" */home/paulus/.config* /etc/xdg
DownloadLocation: "Download" */home/paulus/Downloads*
GenericCacheLocation: "Shared Cache" */home/paulus/.cache*
GenericConfigLocation: "Shared Configuration" */home/paulus/.config* /etc/xdg
AppDataLocation: "Application Data" */home/paulus/.local/share/QtProject/qtdiag* /usr/local/share/QtProject/qtdiag /usr/share/QtProject/qtdiag /var/lib/snapd/desktop/QtProject/qtdiag
AppConfigLocation: "Application Configuration" */home/paulus/.config/QtProject/qtdiag* /etc/xdg/QtProject/qtdiag
File selectors (increasing order of precedence):
en_US unix linux ubuntu
Network:
Using "OpenSSL 3.0.2 15 Mar 2022", version: 0x30000020
Platform capabilities: ThreadedPixmaps OpenGL ThreadedOpenGL WindowMasks MultipleWindows ForeignWindows NonFullScreenWindows NativeWidgets WindowManagement SyncState RasterGLSurface SwitchableWidgetComposition
Style hints:
mouseDoubleClickInterval: 400
mousePressAndHoldInterval: 800
startDragDistance: 10
startDragTime: 500
startDragVelocity: 0
keyboardInputInterval: 400
keyboardAutoRepeatRate: 30
cursorFlashTime: 1000
showIsFullScreen: 0
showIsMaximized: 0
passwordMaskDelay: 0
passwordMaskCharacter: U+25CF
fontSmoothingGamma: 1.7
useRtlExtensions: 0
setFocusOnTouchRelease: 0
tabFocusBehavior: Qt::TabFocusAllControls
singleClickActivation: 0
Additional style hints (QPlatformIntegration):
ReplayMousePressOutsidePopup: 0
Theme:
Platforms requested : unknown,generic
available : gtk3
Styles requested : Fusion,Windows
available : Windows,Fusion
System font : "Sans Serif" 9
Fonts:
General font : "Sans Serif" 9
Fixed font : "monospace" 9
Title font : "DejaVu LGC Sans" 12
Smallest font: "DejaVu LGC Sans" 12
Palette:
QPalette::WindowText: #ff000000
QPalette::Button: #ffefefef
QPalette::Light: #ffffffff
QPalette::Midlight: #ffcacaca
QPalette::Dark: #ff9f9f9f
QPalette::Mid: #ffb8b8b8
QPalette::Text: #ff000000
QPalette::BrightText: #ffffffff
QPalette::ButtonText: #ff000000
QPalette::Base: #ffffffff
QPalette::Window: #ffefefef
QPalette::Shadow: #ff767676
QPalette::Highlight: #ff308cc6
QPalette::HighlightedText: #ffffffff
QPalette::Link: #ff0000ff
QPalette::LinkVisited: #ffff00ff
QPalette::AlternateBase: #fff7f7f7
QPalette::NoRole: #ff000000
QPalette::ToolTipBase: #ffffffdc
QPalette::ToolTipText: #ff000000
QPalette::PlaceholderText: #80000000
Screens: 1, High DPI scaling: inactive
# 0 "XWAYLAND0" Depth: 24 Primary: yes
Manufacturer:
Model:
Serial number:
Geometry: 2560x1440+0+0 Available: 2560x1440+0+0
Physical size: 677x381 mm Refresh: 59.9606 Hz Power state: 0
Physical DPI: 96.0473,96 Logical DPI: 96.0473,96 Subpixel_None
DevicePixelRatio: 1 Pixel density: 1
Primary orientation: 2 Orientation: 2 Native orientation: 0 OrientationUpdateMask: 0
LibGL Vendor: Microsoft Corporation
Renderer: D3D12 (NVIDIA GeForce RTX 2060)
Version: 4.2 (Compatibility Profile) Mesa 23.0.4-0ubuntu1~22.04.1
Shading language: 4.20
Format: Version: 4.2 Profile: 2 Swap behavior: 0 Buffer size (RGB): 8,8,8
Profile: None (QOpenGLFunctions_4_2), Core (QOpenGLFunctions_4_2_Core), Compatibility (QOpenGLFunctions_4_2_Compatibility)
Unable to create a Vulkan instance, error code is-9
Qt Rendering Hardware Interface supported backends:
OpenGL (with default QSurfaceFormat):
Min Texture Size: 1
Max Texture Size: 16384
Max Color Attachments: 8
Frames in Flight: 1
Uniform Buffer Alignment: 1
Supported MSAA sample counts: 1,2,4,8
Features:
- MultisampleTexture
v MultisampleRenderBuffer
- DebugMarkers
- Timestamps
v Instancing
- CustomInstanceStepRate
- PrimitiveRestart
v NonDynamicUniformBuffers
v NonFourAlignedEffectiveIndexBufferOffset
v NPOTTextureRepeat
- RedOrAlpha8IsRed
v ElementIndexUint
- Compute
v WideLines
v VertexShaderPointSize
v BaseVertex
- BaseInstance
v TriangleFanTopology
v ReadBackNonUniformBuffer
v ReadBackNonBaseMipLevel
Texture formats: RGBA8 BGRA8 R8 R16 RED_OR_ALPHA8 RGBA16F RGBA32F R16F R32F D16 D32F BC1 BC2 BC3 ETC2_RGB8 ETC2_RGB8A1 ETC2_RGBA8
regards
Paul
