Crash when merging scans on Linux (kubuntu)
Posted: Sun Nov 26, 2023 7:11 am
I am experiencing a crash when I try to "merge" 21 small scans in an imported .E57 file. The total file size for the .E57 is 2.5GB.
The crash occurs in the latest beta 2.13, the currently installed 2.12.4 (flatpak) and the older 2.11 (.deb i think?) which is in the Kubuntu software repo/Discover.
To reproduce, I simply select all scans, click "merge" and when prompted to regen scalar fields I select yes or no (makes no difference) and then the program immediately closes.
Launching CC from the console allows me to capture the below error when it crashes
Details of my system:
CloudCompare: /run/build/CloudCompare/libs/qCC_db/src/ccPointCloud.cpp:991: const ccPointCloud& ccPointCloud::append(ccPointCloud*, unsigned int, bool): Assertion `false' failed.Details of my system:
OS: Kubuntu 23.10 x86_64
Kernel: 6.5.7-060507-generic
Uptime: 27 mins
Packages: 2532 (dpkg), 9 (flatpak), 14 (snap)
Shell: bash 5.2.15
Resolution: 3840x2160
DE: Plasma 5.27.8
WM: KWin
WM Theme: Breeze
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], McMojave-circle-dark [GTK2/3]
Terminal: konsole
Terminal Font: Ubuntu Mono 10
CPU: AMD Ryzen 9 5950X (32) @ 3.400GHz
GPU: NVIDIA GeForce RTX 3060 Ti Lite Hash Rate
Memory: 3980MiB / 31990MiB
