State Plane Coordinate System Support
Posted: Mon Apr 10, 2023 4:57 pm
Does Cloud Compare properly preserve the State Plane Coordinate System on export? I see it translates when you open it. But I believe there is metadata embedded in the file to indicated which coordinate system (EPSG code) it is. I loaded, edited, then saved a point cloud using the default precision setting and when I tried to load the point cloud into Agisoft Metashape (previously known as Photoscan) it gave me an error about an infinite value.
