Can't export .e57 with images
Cloudcompare_User_6
Post by Cloudcompare_User_6 »
Hello, I am using the latest version of 2.13 alpha. When I import an .e57 file, I can see the images in the DB tree. However, when if I export to an .e57 and bring it back into CloudCompare, the images are lost and I get a 'failed to load image from blob data' error in the console. I would like to import an .e57 in cloudcompare, make edits, and then export as an .e57 retaining all the images".
Re: Can't export .e57 with images
Ouch! This was a bug. I fixed it. You should download an re-install the latest 2.13.alpha version.
Cloudcompare_User_6
Thanks so much for the quick response!
Kjaerdk
Post by Kjaerdk »
Hi
I have download the lastest 2.13. Alpha version in hope to export at segmented area off the pontcloud and still keep the images.
Is this not passable ?
I can see the Images of all the setup in the DB tree, But when i am uploading it to Atis-cloud, the Images are not there. What am i doing wrong?
I have tested on my side with the latest 2.13.beta version, and it seems to work fine?
Can you retry?
