SF Legend in CCViewer
pmr
Post by pmr »
Is it possible to change the text in the SF legend, that is, to change the scalars to text?
Re: SF Legend in CCViewer
Ah no, currently it's only numbers, but that's a good idea!
We could add a specific syntax in the color scale definition dialog, next to each numerical step:
-1.0 "min"
0 "zero"
1.0 "max"
And CC would use the string instead of the numerical value (if any)
I'll try to work on that idea.
pmr
Post by pmr »
Thanks Daniel.
Ok, so this was fairly easy.
The latest 2.13.alpha version online (today) now allows you to add a text label (between double quotes) next to the custom label value. This text will be displayed instead of the numerical value.
I'll let you test.
pmr
Post by pmr »
Thanks. I'm gona try.
pmr
Post by pmr »
It works! Thanks a lot. Can we import the color scale to use in command line?
Hopefully yes? Just save it as xml and load it with the right command. Please report if this doesn't work.
