ASCII EXPORT - Only X,Y,Z
JoeKan
Post by JoeKan »
Would it be possible to add an ASCII EXPORT option to export only ASCII "XYZ" variables?
This is for import into software that only uses those 3 variables (like Engineering software).
With the current ASCII Export, I have to take the output file, break it into smaller files that Excel will accept (even the current version is limited to 1 million points), then cull the other variables so only XYZ remains. Then rejoin all the files to create a single XYZ for import.
It'd be GREATLY appreciated... :)
Thanks for listening...
JoeK
jdv56a
Re: ASCII EXPORT - Only X,Y,Z
Post by jdv56a »
I do it like that.
I remove all the scalar, color, normal, etc. fields from the cloud. Then I export it as ASCII, since it does not have, CE, RGB, or normal, it only exports X,Y,Z.
Regards
DA523
Post by DA523 »
clone pointscloud
select cloned pointscloud
Edit menu --- normal--- clear
Edit menu --- scaler field ---delete all
save
JoeKan
Post by JoeKan »
Thank You all.
