Create a new layer of just ground points (already classified)
okay
Post by okay »
Hi -
I'm trying to make a separate layer of just the ground points in my point cloud. In other words, I want to be able to turn on and off a plot of just the ground points. I know about the CSF plug, but this isn't necessary to use since the point cloud is classified. I can only figure out to how filter by value, but not by classification. Thanks.
Re: Create a new layer of just ground points (already classified)
Maybe you can use the new 'qCloudLayers' plugin?
Another way, maybe more simpler, is to use the 'Edit > Scalar fields > Split cloud (integer values)' method. This will create as many (sub) clouds as classes present in your cloud.
