How do I apply RGB data to a cloud?
Posted: Fri Aug 05, 2022 6:28 pm
by jnt46321
I want to apply rgb data to a cloud point from an image and or .tiff file. Anyone know how I can do this?
Re: How do I apply RGB data to a cloud?
Posted: Sun Aug 07, 2022 12:39 am
Sadly, CloudCompare doesn't' allow to do that...
Posted: Mon Aug 08, 2022 7:09 am
by westergu
One way to do it is to load the image file as a cloud with the Ellipse marking plugin. Then remove the colors (RGB) from the target cloud and move the image cloud in vertical direction to overlap the target cloud. After that, select both clouds and use Edit|Colors|Interpolate from an other entity.
The method is perhaps not 100% accurate, but it works.
Best regards
