point to triangle registration
Alexmer12345
Post by Alexmer12345 »
I am a newbie of cc,can you tell me in point to triangle registration,how to find the nearest triangle of each point?I have read the source code but I can not understand.
Re: point to triangle registration
Well, that's a bit tricky, but the brute force code is to test all triangles and take the one that gives the smallest distance. Then, in CC, we use a kind of grid structure in which we remember, which triangle(s) intersect each cell. Then it helps to reduce the number of comparisons a lot.
This structure is here: https://github.com/CloudCompare/CCCoreL ... rsection.h
But you would have to mimic the way it's used by the C2M algorithm to find the nearest triangle for each point..
