Contant intensity scale after segmentation
Posted: Fri Apr 29, 2022 8:54 am
Today I noticed that having intensity SF displayed, after chopping the cloud, segments had different "brightness".
I noticed that in "SF display params" the display ranges where not the ranges from the original cloud but they had adapted to the values withing that new cloud. I also noticed that I canĀ“t manually force higher display range than the values present in the cloud. Resulting in a patchwork of display ranges.
Hence, I would like to request to
1) the segmented clouds to have the same display range as the cloud they're detahced from
2) be manually possible to set display ranges higher-smaller than the data included in the cloud so it is possible to display uniformly intensity between tiles of the same dataset
This is not only a visual issue, but affects when mergin the SF with RGB hence it dificults to have an standarized workflow for a tile set.
