Page 1 of 2
Compute 2.5D Volume Report Questions
Posted: Thu Feb 03, 2022 3:38 pm
by asart
Hey!
I'm sorry if I'm asking a dumb question and misunderstanding something fundamental, but I cannot understand some of the values from the volume computation tool.
I am currently trying to estimate earthworks volume between two sequential aerial scans.
I've been looking at the volume computation algorithm in the source and the help.
I believe I have a somewhat decent understanding of the algorithm, but I cannot understand why Volume is computed, essentially, as (Added volume - Removed volume).
Shouldn't the two be added as an absolute value in order to get a total volume?
Also, as a physical representation, how can I visualize what volume is, as it is currently output?
A sample output I have is:
Volume: -918.158
Surface: 972.500
Added volume: (+)22.691
Removed volume: (-)940.849
Matching cells: 58.9%
Non-matching cells:
ground = 0.0%
ceil = 41.1%
Average neighbors per cell: 7.5 / 8.0
Just a sidenote: I am aware that this is a bad cell matching count.
Essentially, with the framework of earthworks in mind, one could look at Added volume as Embankments and Removed volume as Excavations. What then would the purpose of the Volume field be, since it is not the combined volume of both?
Also when computing between the first scan and an arbitrary constant height, and a different scan and the same constant height, shouldn't the difference between the two Volume fields be the same as if I did the comparison between the two clouds?
I am sorry for the novel I've written instead of a post.
Thank you!
Re: Compute 2.5D Volume Report Questions
Posted: Thu Feb 03, 2022 4:25 pm
The total volume is indeed the difference between the 'added' and 'removed' volumes:
22.691 + (-940.849) = 22.691 - 940.849 = -918.158
If you have a perfectly flat terrain. Then add X m^3 of dirt somewhere, and remove Y m^3 of dirt somewhere else, then the new volume of dirt will be the previous one, plus 'X - Y'.
People using this tool are generally not interested in summing the volume of 'air' inside the excavations, and the volume of dirt in embankments. If you are, then I guess you'll just have to do the computation manually...
Posted: Thu Feb 03, 2022 4:43 pm
by asart
Thank you for the quick reply!
That is a fact, but my question then becomes:
If I have two perfectly flat terrains, which cross at a given angle, then the value of Volume added would be the same as the value of Volume removed.
In that case would the Volume be 0?
Posted: Thu Feb 03, 2022 4:45 pm
The volume 'difference' yes. Since this tool asks for a 'before' and an 'after'.
If you want to compare both to a common flat terrain at Z = 0 for instance, then you'll have to compute the difference between each cloud and the common reference. But that would probably be equivalent in the end to manually compute the sum of the absolute volumes. However, mind that you are summing 'air' and 'dirt'... which may not make sense depending on your application.
Posted: Thu Feb 03, 2022 4:53 pm
by asart
Unfortunately that is precisely what I am after.
How would I then compute them by hand?
Are there tools I could use in CC to compute just the 'air' and 'dirt' separately?
Thank you for your patience!
Posted: Thu Feb 03, 2022 4:55 pm
Well, CloudCompare displays the added and removed volumes separately? So you just need to do the maths?
22.691 + 940.849 = 963.54
Posted: Thu Feb 03, 2022 5:00 pm
by asart
Aha!
Thank you for answering simple questions.
So I'm safe in understanding that Added volume would be the Embankments and Removed volume would be the Excavations then.
Posted: Thu Feb 03, 2022 5:01 pm
Well, it depends on what the 'before' cloud (or altitude) is? If it's a flat terrain/plane, then yes.
Posted: Thu Feb 03, 2022 5:22 pm
by asart
I see.
In that case if I calculate the volume of the before cloud and a constant height, and then the volume of the after cloud and the same constant height, shouldn't the difference between those two volumes be the same as if I calculated the total volume (i.e. the sum of 'dirt' and 'air') of the before and after cloud?
Sorry if that sounds a bit unclear.
So 'before' and a constant height of 69.83:
Volume: 560.248
Surface: 1,652.250
Added volume: (+)715.705
Removed volume: (-)155.458
Matching cells: 31.6%
Non-matching cells:
ground = 68.4%
ceil = 0.0%
Average neighbors per cell: 7.7 / 8.0
'After' and a constant height of 69.83:
Volume: 928.421
Surface: 779.250
Added volume: (+)928.421
Removed volume: (-)0.000
Matching cells: 15.1%
Non-matching cells:
ground = 84.9%
ceil = 0.0%
Average neighbors per cell: 7.3 / 8.0
And the before and after:
Volume: -1,172.158
Surface: 1,041.000
Added volume: (+)27.766
Removed volume: (-)1,199.924
Matching cells: 63.0%
Non-matching cells:
ground = 37.0%
ceil = 0.0%
Average neighbors per cell: 7.6 / 8.0
So if X = "715.705 + 155.458 = 871.163" and Y = "928.41", shouldn't Y - X equal a value in the computation between 'before' and 'after'?
Posted: Fri Feb 04, 2022 8:10 pm
by DA523
BIN FILE 2 pointsclouds
13.7z
(1.73 MiB) Downloaded 1415 times
