[Done] Geological plane orientation
Posted: Thu May 19, 2011 9:16 am
People, hi,
Would it be possible to implement some functionality to measure plane attitude? Does it exist already?
A first quick and dirty solution is to fit a plane with the 3 points picking tool and provide it's normal. I can do that easily enough even with Excel. The idea would be to have displayed in the console.
A second more usefull solution is to compute the normal vector to a LS plane defined by these 3 points.
A third, more practical for geosciences it to convert the normal vector into dip (inclination of the plane from the horizontal with respect to XY plane, expressed in degrees) and strike (compass direction of a coplanar horizontal line - angles expressed in decimal degrees counted clockwise with 0° the Y axis)
And icing on the cake, describe the coplanarity and colinearity of a point set segmented automatically around a manual seed point. A good starting point to implement the moment of inertia is the paper by Oscar Fernandez, 2005, Journal of Structural Geology which I can provide offline.
Cheers,
ThomasD
Cheers,
ThomasD
