DB tree workflow question
JManning
Post by JManning »
Fairly new to CC... I have a couple questions about workflow speed.
When I load an E57 that has many scans in it, is there a way to select them all and change all the Colors to RGB instead of Scalar in one fell swoop?
Would also like to be able to select a group of scans and turn their checkboxes on or off in one action instead of clicking on each, one at a time.
Thanks!
Re: DB tree workflow question
Yes, you can either select the top group, or select all the clouds (there's even a 'Select children by type and/or name' option when you right click on a group).
Then use the 'Toggle' options (Edit > Toggle > ...) and you also have keyboard shortcuts that appear next to the menu entries (SF = 'S', Colors = 'C', etc.).
And to enable/disable, it's 'A'.
JManning
Post by JManning »
Perfect! Thanks for answering something I'm sure is in the documentation already :-)
