Translate Plane Parallel to Normal
Posted: Thu Sep 23, 2021 7:33 pm
Is there an easy way to translate a plane parallel to its normal? I'd like to fit a plane to a set of points and then apply an offset to the plane along its normal. I think using "align camera" on the plane, applying the transformation to the points and plane, and then moving the plane along the y axis will work but wondering if there is a simpler way as I have many objects to process. I'd also like to avoid applying a transformation to the points.
Thank you,
Cody
Thank you,
Cody
