Camera position estimation from 3D points
K.Rothwell
Post by K.Rothwell »
Locate a camera position based on 3D points.
Python might provide an easy way to go about this. I believe there is a lib through OpenCV that has the math already sorted out for Reverse Camera Projection.
I envision a tool similar to the align clouds tool; only you would select 3D points on the cloud and 2D points on a loaded image.
The user would pass through the intrinsic and extrinsic camera parameters... distortion values, principal point, focal length.
I have used other software in the past to do this, but it seems CC would be much more enjoyable to use if it can be done.
Cheers,
Kyle...
Re: Camera position estimation from 3D points
Ah that's definitely doable... But it's a lot of work ;)
