CCViewer - input
pmr
CCViewer - input
Post by pmr »
Hi:
Is there a way of making CCViewer show a point cloud you give as an input parameter instead of having to drag the file into it?
Thanks!
Re: CCViewer - input
Normally you just need to call "ccViewer yourfilename.ext" (with an absolute path to your file, potentially between quotes if there are spaces in the filename).
And you can even put several filenames, one after the other.
