Render to file with SF scale
Posted: Fri Jan 25, 2013 10:09 am
by anagno
Hi all,
Is there a way to export and the SF scale when i use the command "Render to file" ???
Thanks in advance
Re: Render to file with SF scale
Posted: Tue Jan 29, 2013 8:23 pm
I guess we could add a check-box to choose wbether color bar, scale, etc. should be rendered as well (or not).
Meanwhile, you can use the 'print screen' button of your keyboard of course ;)
Posted: Wed Jan 30, 2013 9:04 am
by anagno
Thanks for the info
Posted: Sat Feb 09, 2013 11:25 am
It appeared that it was in fact more like a bug. The next version will output the SF scale by default!
Posted: Thu Apr 18, 2013 12:09 am
by icezigzag
Has this feature to show the scale bar in 'render to file' been updated in the new version?
Posted: Thu Apr 18, 2013 7:38 am
Yes (at least I hope so ;).
And there will be a lot of new features regarding the color scale in the next release (end of the month) such as a color scale editor, the possibility to display the histogram next to the color scale, etc.
Posted: Mon Aug 05, 2013 8:52 am
by AdrienA
I wonder if the problem of the scale is solved in the last version.
Maybe I had not activated the good option but it does not copy the scale bar when I use the Render to file tool.
Does the bug still remaining or do I make a mistake ?
Best regards,
Adrien A
Posted: Tue Aug 06, 2013 7:07 pm
You're right, this has not been fixed in the last release!
We must have missed it... will be for next time (hopefully ;)
Posted: Wed Aug 07, 2013 12:31 pm
by AdrienA
Ok, thanks for your answer.
I will wait using the traditional print screen to save the scale.
AdrienA
Posted: Thu Aug 29, 2013 1:20 pm
Ok it's fixed. It will be available (as an option in the 'Render to file' dialog) in the next release (2.5.1)!
