The ability to simplify based on Z variance
Posted: Thu Jan 14, 2021 9:19 am
Hi. There is a feature that I have wanted in CC forever. The ability to reduce a pointcloud based on the difference in the Z value of neighbours. That's how you classify "model keypoints" in other software. And is the best way to reduce the number of points, without loosing the definition of the terrain, since major variatons are kept, but points in flatter areas are removed. This is a real bottleneck, because most cheap programs can't do this, so you need something like Terrascan or similar to do it (I believe the full version of LAStools also can do it)
Is this something that could be added? that would make Cloud compare pretty much the only tool I need to make high quality DTMs of large areas.
Also, if someone knows a roundabout way to do it the way it is now, I would really appreciate a quick tutorial.
Thank you
Thank you
