Hello I have installed CloudComper.
But when I try to start it I get the following error message.
I also tried to copy the DLL file manually into the paths. Then another error message came up.
I use the following system:
Processor Intel (R) Core (TM) 2 Quad CPU Q6600 @ 2.40GHz 2.40 GHz
Installed RAM 4.00 GB
System type 64-bit operating system, x64-based processor
Edition Windows 10 Pro
Version 20H2
Installed on December 29th, 2020
OS build 19042.685
Performance Windows Feature Experience Pack 120.2212.551.0
Can I tell someone what I have to do to run the program.
Thanks!
The error messages come in the order they are named.
Installation problems
- 4.PNG (47.36 KiB) Viewed 871 times
- 3.PNG (36.2 KiB) Viewed 871 times
- 2.PNG (29.86 KiB) Viewed 871 times
- 1.PNG (30.01 KiB) Viewed 871 times
If you don't know anything, you don't have to do anything.
Re: Installation problems
You should install the Visual Studio 2013 Redistributable package (64 bits): https://www.microsoft.com/en-us/downloa ... x?id=40784
That´s it!
Thank a lot
Thank a lot
