Optimal octree level setting
umangparikh
Post by umangparikh »
I am trying to process 2 large points clouds with size(117M and 260 M points respectively). What would be the optimal octree level setting while doing cloud to cloud comparison, I know it can never be exactly predicted but wanted to know if such high density files need levels greater than 8 or can lower levels work? Also is it true that higher the octree level more is the processing time?
I processed a similar file and it took a day with a setting at level 8. My system is at 32 GB RAM.
Thanks,
Re: Optimal octree level setting
Normally it's automatically deduced by CloudCompare? You should leave it at its default value.
umangparikh
Thank you! The subsampling also really helped, was able to reduce the cloud size considerably and it made CtoC processing faster.
