Sensitivity analysis M3C2
jub
Post by jub »
Hello!
I'm using M3C2 to process some bathymetric data. I have tried different values in normal diameter, projection diameter and number of core points in order to see which one was better for my datasets.
Now I want to do a sensitivity analysis with these parameters to explain, objectively, which values are better. I have save output data from M3C2 distance pluggin but I don't know how to see the influence of normal and projection diameter and number of core points in my data.
Thank you for your help!
Re: Sensitivity analysis M3C2
Appart from the variations in distance you mean? Or how to compute / process these variations?
