How to color a mesh or a points cloud from a geotif ?
Posted: Mon Sep 07, 2020 11:34 am
by thomas.touze
Hy everybody,
I've got a 1km x 1 km scene with a 1m resolution. I have successfully imported a DTM, from a LiDAR survey, and a geotif.
I would like to color the DTM with the geotif, but I can't find how to proceed.
I have tried >> Edit > Colors > Interpolate from another entity
But cc tells me it can't proceed because "clouds are too far from each other".
Indeed, my geotif has a 0 altitude whereas my DTM is around 500 m.
Has anyone an idea to solve this ?
Best regards,
Thomas.
Re: How to color a mesh or a points cloud from a geotif ?
Posted: Tue Sep 08, 2020 10:38 am
Do you mean that your geotiff is flat?
Posted: Wed Sep 09, 2020 3:43 pm
by thomas.touze
Good afternoon Daniel,
Yes it is flat.
You can have a look here:
Best regards
Thomas.
Posted: Wed Sep 09, 2020 8:24 pm
Hum, sadly, even if this looks silly, CC can only manage interpolation between 3D entities (as it relies on the nearest neighbor for each point to do it)...
Posted: Thu Sep 10, 2020 6:13 am
by thomas.touze
OK, I supposed so.
Thank you for your time.
Best regards
Thomas.
Posted: Mon Sep 14, 2020 5:25 pm
by WargodHernandez
I wonder (without researching it much), if you could make this work by exporting your coordinates to scalar fields to save the 3d coordinates.
Edit->Scalar fields->Export coordinate(s) to SF(s)
Then create a constant scalar field with a value of 0.0 and a name of "ZZero"
Edit->Scalar fields->Add constant SF
Then select "Coord. Z" as the active scalar field in the properties window and rename to something else like "ZOrig"
Then select "ZZero" as the active scalar field in the properties window and rename to "Coord. Z"
Then we set set our SF as coordinate (This command takes the SF named "Coord. Z" and applies the values in the SF as the new coordinates which should all be zero)
Edit->Scalar fields->Set SF as coordinate(s)
Then select both the cloud and the tif and interpolate the color from tif to the cloud
Edit->Colors->Interpolate from another entity
Then delete "Coord. Z" and rename "ZOrig" to "Coord. Z" and finally set SF as coordinate to restore the 3d cloud
Posted: Tue Sep 15, 2020 1:04 pm
Ah! It might work indeed (since the clouds are dense and all)
Posted: Tue Nov 23, 2021 5:32 pm
by pbrgle1
Thank you WargodHernandez! Works like a charm! :)
I used your technique to colourize the vegetation, which is then used in Twinmotion for diagrammatic (but accurate) architectural visualizations.
