Outliers on histogram
Posted: Sat Jun 13, 2020 7:37 am
by zakrzewska.angie
is there any chance to show on histogram how changed numbers of outliers in cloud (after for example noise filtering, csf etc)?
Re: Outliers on histogram
Posted: Sat Jun 13, 2020 4:34 pm
Not sure to understand your need? Can you clarify?
Posted: Sun Jun 14, 2020 7:23 am
by zakrzewska.angie
I have two point clouds, both subject to noise filtration, csf algorithm, sor filtration, and I would like to show at each stage how the distribution of points changes and island points / outliers are eliminated. Is it possible to present this with a histogram? Based on calculating the distance from neighbors etc?
Posted: Sun Jun 14, 2020 9:37 am
Well you can always compute the distances between two states of the clouds of course. But I'm not sure how readable that will be.
Another option is maybe to look at the 'density' at various steps?
Posted: Sun Jun 14, 2020 9:45 am
by zakrzewska.angie
I also thought about it, but I wondered if there was another way to present it. Thank you for your answer.
And if there is detailed documentation tool "Calculate geometric elements"?
Posted: Sun Jun 14, 2020 9:57 pm
Not yet. But some of the features were split before in various tools (that are described on the wiki, in the "Tools > Others" menu):
https://www.cloudcompare.org/doc/wiki/i ... hods#Other
