Cloudcompare M3C2 vs C2M signed distance outputs (reference cloud problem!)
Posted: Sat May 02, 2020 1:59 am
I have two mode which using the cloud compare for comparing those together, i used the ordinary distance compare method ( C2M signed method) with this parameter as you can see here:
and for more details i tried also the M3C2 method by this parameters:
but there is difference in output as you can see:
So i think it comes form the M3c2 setting (which one is reference ,cloud #1 or cloud#2?!).
I have tried to give the reference stl file as cloud#1 and target to be compared as cloud#2 as at export part as projection core points on cloud#2 i have tried projection core points on cloud#1 but i have get the same output and it project the colored compare results only on the reference cloud which is Cloud#1 !.
so what is the reason for difference and why it only show the cored output on reference could?!
i have tried to use cloud#2 as reference and the **M3C2 parameters** are this kind now:
and the colored output shown on the target stl mode as you can see here:
, but the difference in output is remained again! you can see here:
asked this Question also here:
https://engineering.stackexchange.com/q ... d-problem
Thanks.
Thanks.
