Exporting raster - georeferencing ?
Posted: Fri Apr 24, 2020 2:00 pm
by betadk@gmail.com
When exporting a raster or image, it seems that the global shift / scale is not restored and the raster is therefore not geo-referenced correctly (point cloud was in UTM). Is one supposed to transform to originals outside of CloudCompare ?
Thanks.
Re: Exporting raster - georeferencing ?
Posted: Fri Apr 24, 2020 4:56 pm
Global shift should be restored when exporting the raster to geotiff (via the 'Rasterize' tool). But indeed, not when exporting to an image.
Posted: Mon Jul 15, 2024 9:50 am
by libak
Hi Daniel
How do I export a rasta to geotiff while maintaining global shift (scale)?
When I import the geotiff into ACAD, the geotiff is 1mm in length which is not correct - the bounding box in CC is ~39000
Rgds
Posted: Mon Jul 15, 2024 3:05 pm
Which version are you using?
And can you explain how you generated the geotiff exactly? From which cloud?
Ideally, if you could share the original cloud and the parameters you used that would help a lot.
