Label Connected Components results in one single component
I'm trying to segment a point cloud into multiple cubes to export seperately since Blender runs out of ram if i import the whole cloud at once. To to this. I tried to use Label Connected Components to split it up but it returns only one Cloud. See files below. Any help is greatly appreciated!
- Octree.png (1.16 MiB) Viewed 2475 times
Re: Label Connected Components results in one single component
Well, the "connected components" are indeed the parts of the clouds that are "connected". As you don't have any hole / ridge here, then you only have one "connected component" in your cloud.
You should use the "repetitive slice/box extraction' option of the 'Cross Section' tool (see https://www.cloudcompare.org/doc/wiki/i ... r_contours).
You can define your initial box, and the tool will repeat the segmentation process by moving the box in one or several dimensions.
