Line Profile in CloudCompare possible?
Posted: Mon Jan 13, 2020 1:34 pm
Hi all together,
is it possible to show/extract a line profile in CC?
I have a tube which I recorded with a terrestrial 3D laser scanner. The scanner records the geometry (X, Y and Z) the color (RGB) as well as the laser reflection intensity (I).
Now I would like to mark a line in my scanned object and see e.g. the geometry of the object and the intensity at this position.
The background is, I have several spectral data on this tube (RGB and two scalars) and I would like to compare the spectroscopy at the very specific surface. It also depends on the geometry of the object, or better, the surface normal to the scanner.
Thank you very much in advance!
![Image](https://gis.fhws.de/edian/CC.jpg)
I have an image here: https://gis.fhws.de/edian/CC.jpg
