Importing LAZ files doesn't work
Posted: Mon Nov 25, 2019 9:10 am
by Florian
When importing .Laz files from the Flemish government (lidar scans they did in 2014/2015), Cloudcompare gives this error:
"PDAL exception: readers.las: reading point 2084566 of 2084547 total points"
When I press "OK" I get this message:
"An error occured while loading 'Name of the scan': the third-party library in charge of saving/loading the file has failed to perform the operation"
I am able to convert the .laz files to .las with laszip, but I was wondering if there is a solution in Cloudcompare? Or is there another solution to make these files work immediately in Cloudcompare?
I tried to put a file in attachment but the file is too large (10.2MB)
Many thanks in advance.
Re: Importing LAZ files doesn't work
Posted: Mon Nov 25, 2019 9:02 pm
Can you maybe send me the file directly? (admin [at] cloudcompare.org)
Posted: Wed Nov 27, 2019 10:06 am
by Florian
I've sent you the file directly. Maybe you can find out what's going on. Many thanks in advance!
Greetings,
Florian
Posted: Wed Nov 27, 2019 9:18 pm
Thanks, I'll investigate why PDAL fails to load this file.
Meanwhile, you can use (with the Windows version) the other LAS import filter ('LAS 1.3 or 1.4') that relies on LASlib.
Posted: Mon May 18, 2020 5:09 pm
by MarianaCampos
Hi everyone,
I'm having the same issue/error to open large point cloud Laz files (~600 million points/ 8GB) generated using LASlib (LAZ Format 1.4).
Las files open as expected for 600 million points and smaller point cloud laz files generated by the same method open ok too (~15 million points)
ERROR:
PDAL exception: readers.las: reading point 0 of 584564737 total points
An error occurred while loading '200218_203502': the third-party library in charge of saving/loading the file has failed to perform the operation
Any solution so far?
Posted: Thu May 21, 2020 6:49 am
Can you maybe open an 'issue' on github? Or maybe ask directly to the PDAL team?
Posted: Thu Apr 21, 2022 10:20 pm
by juandelsur
Hi Mariana,
I am having the same problem that you report. Did you solve it?
MarianaCampos wrote: Mon May 18, 2020 5:09 pm Hi everyone,
ERROR:
