compilation error in ccComanndLineParser.cpp
All about Linux portage
corny335
Post by corny335 »
i faced the following compilations error:
./qCC/ccCommandLineParser.cpp: In member function ‘int ccCommandLineParser::parse(int, char**, bool, QDialog*)’:
./qCC/ccCommandLineParser.cpp:214:112: error: no matching function for call to ‘ccCommandLineParser::Export2BIN(ccCommandLineParser::CloudDesc, const char [18])’
./qCC/ccCommandLineParser.cpp:214:112: note: candidate is:
./qCC/ccCommandLineParser.cpp:102:9: note: static QString ccCommandLineParser::Export2BIN(ccCommandLineParser::CloudDesc&, QString)
./qCC/ccCommandLineParser.cpp:102:9: note: no known conversion for argument 1 from ‘ccCommandLineParser::CloudDesc’ to ‘ccCommandLineParser::CloudDesc&’
probably due to a new version of the gcc, maybe it was a warning in older gcc versions.
It was indeed not hard to fix:
I changed in file ccComanndLineParser.cpp:
QString errorStr = Export2BIN(CloudDesc(&result,cloudFilename,m_clouds.indexInFile),"RANDOM_SUBSAMPLED");
to :
CloudDesc cloudDesc(&result,cloudFilename,m_clouds.indexInFile);
QString errorStr = Export2BIN(cloudDesc,"RANDOM_SUBSAMPLED");
similarly, it needs to be done in line 246 and line 277.
maybe this can be fixed for a new release.
-Cornelius
Re: compilation error in ccComanndLineParser.cpp
Yes, I always wonder why all those compilers change their policies all the time. But MSVC is known to be less strict about the norms, so gcc might be "right".
I've fixed this on the trunk.
Thanks for the feedback.
Daniel
